My windows form application on Labview front panel
witny
The first method that comes to mind is using Windows DLL calls to set the parent window as the LabVIEW front panel, and the child window as your C# application.  This will work but looks a little ugly because you will have the title bar of your C# program inside your front panel and looks unnatural.  I did a quick search and found this post that I think has some code on setting parent/child windows.
http://forums.ni.com/t5/LabVIEW/Set-Parent-window-using-User32-at-lv7-1/td-p/1950469
To do this you'd need the HWND of both the parent and child windows.
I'm betting there is a nicer way to do this and I hope someone else answers because admittedly this feels like a hack method.
I'm not s familiar with C# but LabVIEW does have native support for .net controls. If you can compile it into this it should be possible but it depends on the execution flow of your program.
