Displaying live video.... Without IMAQ
Has anyone had success displaying live video (8bits,480x748) at a high frame >15fps rate not using the IMAQ controls.
I can get the driver to acquire up to 30fps and display the data via a numeric array indicator, but when it comes down to displaying the whole image, it takes me down to about 7-12fps.
I have toyed w/ the intensity graph and found that to be inefficient. 5-7fps max
I have found a solution using the picutre control, but I max out around 12 fps.
Has anyone had success doing this?
Norman J. Kirchner Jr.
Certified LabVIEW Developer
Automation Software Engineer
Engineering Specialists, Inc.
Hello
as i 've mentioned in the mail list, i have write a VFW base (Video for Windows) wrapper for video or image processing under LabVIEW. It works with IMAQ + Vision, but don't needs it !
What do you want to do, image processing or, just showing a live video in your VI ?
Mario
  • 4 months later...
Hello
Mario
3866[/snapback]
Mario,
How can I get my hands on your wrapper?
-Karl
I thought I would wrap up this thread by letting all know of the solution. It's a bit dependent on how much horsepower your PC has but it's PLATFORM INDEPENDENT :thumbup:
SIDE NOTE: Mario, I was just looking to display the image (end side note)
I have found a way to hack into the picture control to allow fast redraws of streaming video. Assuming you get your video data in a 1-d array of U8 (but concept can be adjusted for any vid format). If you use the standard "Draw Unflattened PixMap" for your first frame, to format all the picture data/header info
post-208-1119285363.jpg?width=400
And then for every following frame, simply replace only that portion of the picture data within the bytestream.
post-208-1119285837.jpg?width=400
You can reach framerates in excess of 30 FPS with only the PICTURE CONTROL. There are a number of other assumptions going on here, but for the sake of space I'll stop here.
Happy Hacking
The Captain
  • Like 2
