print program
Hello All
i'm trying take a print from labview
but i do't know
i want take a print all my program on a paper just a paper ! no 1,2,3 paper
i want use a push button  for print on my program
please help me!
So you want to print the source code to your application correct?
Did you try File >> Print?  Or File >> Print Window?  If so what was wrong with doing that?  You can also do it programatically using the Report Generation >> Easy Print VI Panel or Documentation
i do't use file>>print
can you take a image from easy print ?
Maybe you should it sounds like it would meet your needs.
If you are unsure what the function can do open the context help.
