value Inside Array
What you are looking at is an empty array.  If you want to add data, to any array the data must be added at the front, at the end, or inserted in between existing values in the array.  Since you have no existing values in the array, then you can only add values to the front or the end, and both are the same again since the array is empty.
Without knowing more about what you actually want my suggestions may not be appropriate.  One suggestion is to just have an array constant with your data in it.  But if you are replacing data this might not be what you want.  Also you may want to initialize an array with some size and then replace elements in the array.  But again if that isn't what you want, then it won't be of any help.
In any case the functions you'll want are under the Array palette, checkout Build Array, Insert, Delete, and Initialize array.
If you are interested in some free training check out some of these links.  Otherwise try using some of the functions mentioned and post some code of what you've tried.
NI Learning Center
NI Getting Started
-Hardware Basics
-LabVEW Basics
-DAQ Application Tutorials
3 Hour LabVIEW Introduction
6 Hour LabVIEW Introduction
Self Paced training for students
Self Paced training beginner to advanced, SSP Required
LabVIEW Wiki on Training
