infinitenothing Posted December 2, 2014 Report Posted December 2, 2014 (edited) Inspired by these two threads: http://lavag.org/topic/18657-notifiers-not-working-when-use-consecutive-create-notifier-vis-without-delay/ http://lavag.org/topic/4028-notifier-signals-missed/ I was wondering if I could create my own notifier that could switch between references without the history management. Here's what I came up with. I'm not expecting this to be very fast. I thought it was an interesting use case for occurrences. Test Case: Obtain Notifier Wait on notification I probably need a mechanism to check and retry if the "Latest Message Is Valid" flag is false after the "Wait on occurrence". Send Notification Edited December 2, 2014 by infinitenothing Quote
drjdpowell Posted December 3, 2014 Report Posted December 3, 2014 I don’t think you an avoid a history recorded somewhere. Your solution above won’t get notifications that occur between calls to “Wait on Notificationâ€. Though if you were to keep a history of listeners in the Notifier structure (in contrast to the current LabVIEW Notifier that keeps a history of Notifiers in the Wait node), then this might be better, as the list of Wait nodes should be finite, in contrast to the potentially limitless number of Notifiers. Quote
infinitenothing Posted December 3, 2014 Author Report Posted December 3, 2014 You're not supposed to get notifications that occur between WON if you set the ignore flag to true are you? Quote
drjdpowell Posted December 3, 2014 Report Posted December 3, 2014 Oh, I missed that case structure (I can’t read VI snipits on my machine). So you are building a Listener history. 1 Quote
infinitenothing Posted December 3, 2014 Author Report Posted December 3, 2014 It's building a listener list (no time stamp) but it's not stored in the internal state of the WFN. It's limited to how many nodes you have (like you said). Quote
