Baldrick Posted January 9, 2015 Report Posted January 9, 2015 Does anyone know how to launch the DAQmx task (MAX Task) configuration screen with LabVIEW? I would like to have a VI that would launch that screen so user could configure the task and I could use that task later on with my code. Cheers, Samuli Quote
Popular Post hooovahh Posted January 9, 2015 Popular Post Report Posted January 9, 2015 Yup I sure do. The attached VI should allow you to make a new Scale, Virtual Channel, or Task, or edit an existing Scale, Virtual Channel, or Task. I found this stuff while digging around in the DAQ Assistant common files under Program Files\National Instruments\MAX\Assistant. Add - Edit Scale - Task-Channel DAQ Assistant .vi 5 Quote
Baldrick Posted January 13, 2015 Author Report Posted January 13, 2015 Thank you so much! I will test it. Cheers! It was exactly what I was looking for! Thanks! Quote
