read/write CAN Data USB-8473
Sagi
2 hours ago, carl078 said:
I already installed these drivers. Can't I use the XNET examples if I install the NI-XNET Compatibility Library for NI-CAN? Installing the NI-XNET Compatibility Library for NI-CAN - NI
No you can't.  This lets you use XNet hardware (which I don't think you have) but use the older NI-CAN drivers.  This was intended to help developers transition to the newer XNet hardware but use their old software.  You cannot use any XNet sessions on the 8473 hardware.
51 minutes ago, carl078 said:
Is it possibile that I can't see the NI CAN library examples because in MAX I have only 64bit Labview Runtime?
Probably. Again NI-CAN drivers, which you need to use your 8473, only work on LabVIEW 32 bit.  Do you have LabVIEW 32 bit installed? Do you have the NI-CAN drivers installed? Do you see the "CAN" palette under Measurement IO?  If not then you need to resolve this.  Sorry.
