write three different values in serial buffer using case structure according to comparison value
here i have uploaded VI file. here i am changing amplitude according to slider.wave is displayed on graph.if ampltude is greater than 0.6 then LED on.and case structure write 1 in buffer. if amplitude is less than 0.6 v than case structure write 0 in buffer. now i want to like that  if my amplitude is between 0.2 to -0.2. then led on and it will write 2 in buffer. how can we do that??. can you help me?
I don't think you attached code as you had intended but have you considered putting a case structure in your <0.6 case that would trigger in a range. You could use the "In Range and Coerce" function and wire the "In Range?" output to the inner case selector.
Edited by infinitenothing
I would multiply by 10 and then wire the result directly into the case selector.  You can then make ranges and proceed as needed in each case.
