Create type def and then use it
If you want to use the New VI Object VI to insert a custom control you need to feed it a valid path and set the Class input to GObject or a class it inherits from. I would be interested to know if there is a way around this but I think you will also need to save the .ctl (at least temporarily) so you have a valid path to reference.
To explain the error you were getting, you were telling LabVIEW to put whatever was at the path "Control 1" into your new VI.  That isn't a valid path so LabVIEW just gave an error saying that it couldn't create that object.
-Matt J
  • 3 weeks later...
I'm pretty sure you could do it without saving.  You'd have to get a reference to the VI in memory, and insert that instead of using it by path, but this design is easier to implement and understand, but by name is probably possible.
