mudasir Posted January 12, 2016 Report Posted January 12, 2016 hi i have 50HZ sinusoidal signal as a referance signal and i want to measure the present/current degree of running waveform very precisely and accurately , means as one cycle contains the degrees from 0 to 360. for e.g. if current degree is 5 then output must b single scalar 5. and if current degree is 250 then it gives output 250. i use simulate signal block and do the settings of getting 50Hz signal then i attach extract single tone block and get output from detected phases (degree) but the output contains data like an array which i cannot extract because i am new user of labview. is there any way to measure current degree of running waveform one by one as waveform oscilate and change the degree and send scalar data (single data) present degree to some where else for comparison. kindly help me i will be highly thankful to you. thank in advance with best regards mudasir ahmed internal.vi Quote
Tim_S Posted January 12, 2016 Report Posted January 12, 2016 I don't have v2015 to look at your code. You don't list what hardware you are using and your update rate. If you're doing this post-processing, then it should be very possible. If you're trying to do this live with millisecond update rates on a Windows PC, then it cannot be done. Quote
hooovahh Posted January 12, 2016 Report Posted January 12, 2016 Crosspost #1 Crosspost #2 (linked in #1) The code isn't doing much. Besides needing 2015 you also need the control and simulation toolkit for some reason. This is a post processing technique with the Simulate Signal being used for now. A while ago I had a need to look at every cycle of a square wave looking for drop outs. Here is my post on NI's forums with a VI at the end which could detect if one cycle was missing. Using a modified version you can look at each cycle of the sine wave. http://forums.ni.com/t5/LabVIEW/Detect-PWM-Drop-Out/td-p/2610921 Quote
mudasir Posted January 13, 2016 Author Report Posted January 13, 2016 Dear sir my circuit is attached herewith which i want to control using labview code using co-simulation mode. kindly help me how i measure degree of 50 HZ sine wave at every instant and do switching decisions accordingly. please help me with best regards mudasir ahmed Quote
