drummaniac83 Posted January 22, 2016 Report Share Posted January 22, 2016 I'm working on a login/privilege escalation feature that uses domain user/PW and got LDAP authentication figured out, but I was hoping to avoid just using a labview string control for the password entry b/c of security (VI Server, unencrypted, etc). I am trying to call CredUIPromptForWindowsCredentials and launch the native windows login dialog. It is a function in the System32\credui.dll but I can't get the parameters right. I keep getting a return value of A0(160) and no dialog. I think it is the PCREDUI_INFO type screwing it up. It needs: DWORD WINAPI CredUIPromptForWindowsCredentials(_In_opt_ PCREDUI_INFO pUiInfo,_In_ DWORD dwAuthError,_Inout_ ULONG *pulAuthPackage,_In_opt_ LPCVOID pvInAuthBuffer,_In_ ULONG ulInAuthBufferSize,_Out_ LPVOID *ppvOutAuthBuffer,_Out_ ULONG *pulOutAuthBufferSize,_Inout_opt_ BOOL *pfSave,_In_ DWORD dwFlags); I've been told that Rolf would be able to solve this in 30 seconds. Help me LAVA! You're my only hope! Quote Link to comment
Rolf Kalbermatter Posted January 22, 2016 Report Share Posted January 22, 2016 I'm working on a login/privilege escalation feature that uses domain user/PW and got LDAP authentication figured out, but I was hoping to avoid just using a labview string control for the password entry b/c of security (VI Server, unencrypted, etc). I am trying to call CredUIPromptForWindowsCredentials and launch the native windows login dialog. It is a function in the System32\credui.dll but I can't get the parameters right. I keep getting a return value of A0(160) and no dialog. I think it is the PCREDUI_INFO type screwing it up. It needs: DWORD WINAPI CredUIPromptForWindowsCredentials( _In_opt_ PCREDUI_INFO pUiInfo, _In_ DWORD dwAuthError, _Inout_ ULONG *pulAuthPackage, _In_opt_ LPCVOID pvInAuthBuffer, _In_ ULONG ulInAuthBufferSize, _Out_ LPVOID *ppvOutAuthBuffer, _Out_ ULONG *pulOutAuthBufferSize, _Inout_opt_ BOOL *pfSave, _In_ DWORD dwFlags ); I've been told that Rolf would be able to solve this in 30 seconds. Help me LAVA! You're my only hope! Someone certainly has a very unrealistic view about me here! Your problem are most likely the embedded pointers inside the structure pUiInfo, While it's possible in LabVIEW to allocate memory buffers and assign the resulting pointer to the entry in the cluster it is a big hassle. Also the structure needs to be different for 32 bit and 64 bit LabVIEW since pointers and Handles in Windows are of the size of the system too. An extra problem might be that on the MSDN page there is a user comment that claims that the ANSI version of this function is not working properly. Since LabVIEW uses ANSI strings everywhere this would require your strings to be translated to widechar UTF16 and then to call the W function. All in all it is a lot more work than 30 seconds for sure. And I'm not even sure it is so much safer. The Windows dialog uses Windows controls and they can be targeted from a different process with enough privilege escalation. The LabVIEW controls on the other hand are a lot harder to target from outside the LabVIEW process since they are fully implemented in LabVIEW itself. It would actually help to see what you have done so far. If it is something minor I'm certainly willing to point you into the right direction but I have no inclination at all to build this from scratch. Quote Link to comment
GregFreeman Posted January 22, 2016 Report Share Posted January 22, 2016 Someone certainly has a very unrealistic view about me here! You let me down Quote Link to comment
