Popular Post QueueYueue Posted March 8, 2016 Popular Post Report Share Posted March 8, 2016 I gave a presentation at the America's CLA summit this year where I introduced the MGI Solution Explorer. Here's the link to the presentation information and some documentation (that will be expanded) for the tool. MGI Solution Explorer Info Feel free to post feedback here. 3 Quote Link to comment
Ravi Beniwal Posted March 10, 2016 Report Share Posted March 10, 2016 That was a great presentation and certainly a great tool. Thanks! Quote Link to comment
Manudelavega Posted March 10, 2016 Report Share Posted March 10, 2016 Great presentation, thanks Derek. Quote Link to comment
StefanLemmens Posted September 19, 2017 Report Share Posted September 19, 2017 It's a great tool. I noticed that I can run it from the command-line. By using the following command: "MGI Solution Explorer.exe" <path_to_lvsln> -B it will open the tool and start the build process. Unfortunately the first thing that happens is a warning dialog asking me to make sure all changes are saved before proceeding. Is there any workaround to avoid this dialog so we can use the tool in our continuous integration and let it generate (nightly) builds without any user interaction? Quote Link to comment
0_o Posted September 19, 2017 Report Share Posted September 19, 2017 This is a very bad tool since I'll end up losing my prestige as the LVLibP guru at work. All the hard learned issues with PPLs that I was solving for my co workers will now be a non issue All jokes aside... You rock! PPLs are non trivial and, hopefully, your tool will bring the good while keeping the bad away. Thanks! Quote Link to comment
SaphirMountainClimber Posted July 12, 2018 Report Share Posted July 12, 2018 On 19/09/2017 at 3:11 PM, StefanLemmens said: It's a great tool. I noticed that I can run it from the command-line. By using the following command: "MGI Solution Explorer.exe" <path_to_lvsln> -B it will open the tool and start the build process. Unfortunately the first thing that happens is a warning dialog asking me to make sure all changes are saved before proceeding. Is there any workaround to avoid this dialog so we can use the tool in our continuous integration and let it generate (nightly) builds without any user interaction? It's a great tool that my team already used with benefit in the past. However, I'm trying to do the same thing as StefanLemmens in the post above : using MGI SX in a continuous integration process. I have 2 problems : - the same one as StefanLemmens : the popup displayed when MGI launched via command line. Is it possible to bypass it ? StefanLemmens, did you find a solution ? - the second one is : when used with LV2017-64Bits, MGI SX do not find LV and show this error message : 11:40:20 - Initializing LabVIEW Connections 11:40:20 - Connecting to LV 2017 11:40:20 - - generated the following error: Error Code: 5011 Error Details: Unable to find requested version of LabVIEW. Requested Version: 2017 11:40:20 - Build Failed. Of course, LV is installed as MGI SX can load the project when I configure the .lvsln. I never had this problem when I usee it with LV2014-64bits Do you have any ideas ? Thanks for your support! Quote Link to comment
StefanLemmens Posted July 13, 2018 Report Share Posted July 13, 2018 I didn't solve that problem with the popup dialog. In stead we are using the CLI of LabVIEW 2018 for contiuous integration. This is installed with LabVIEW 2018 as a shared resource and is backwards compatible with older versions. I believe back to 2014. Quote Link to comment
SaphirMountainClimber Posted July 13, 2018 Report Share Posted July 13, 2018 Thanks for the reply. I am in touch with MGI support. I'll post back if I have any news. At first glance, 64 bits LabVIEW are not supported Quote Link to comment
molsen Posted September 8, 2020 Report Share Posted September 8, 2020 Another question: Anybody knows if it is possible to add the version to the SFX output filename? Something like: Output name="Teststand package <version> " Resulting in a filename: "Teststand package v 1.0.0.2.exe" I would also like to add the version in the shell command. How to do that? Quote Link to comment
