Set Event on Register Event Callback Node
A_nd_y
Through scripting?  Looking at the available classes I think your only option is going to be to save a VI somewhere that has the register event callbacks configured the way you want, then programatically copy and paste them in.
The reason I suggest this is because the Register Event Callback node appears as to be in the GrowableFunction class, and that has no methods (private or public) that can set the method of it.
So the only solution I can think of is to make a VI that you'll use as a template, and it can have all the nodes configured the way you want and just sitting on the BD.
