Distributed Hash Tables (DHT)
Has anyone worked with, implemented or investigated  DHTs in LabVIEW?
I'm particularly interested in Kademlia/S/Kademlia and Chord so would appreciate any input specifically about those, but any other DHTs that have been played with would be great for discussion.
Out of curiosity what are you using this for?
I've recently been looking at zookeeper/etcd/consul which aren't hash tables but just distributed key-value stores used for service discovery and 'global' configuration. I need a way to locate which one of many distributed devices is producing which data, and I thought one of those might be a good fit for the job. In this case, both libraries have a http interface so the 'interface with lv' part is easy. But I am curious how your dht use case compares with this service discovery use case.
Edited by smithd
I have several use cases in mind with the usual software distribution and distributed databases/file systems. A few others too that are closer to what you are describing but they are more a case it could be used but there are probably better ways-I would know more later.
Service discovery is a means to an end for DHTs if you consider supplying a key-value pair a service. The difference between Kademlia and Chord is basically how they search and contact providers of specific key-value data with an expectation that someone will but without caring who. If one of each service is expected in a system then I'm not sure what would be gained and there would certainly be much faster ways but if you wanted to spread configuration data amongst all services for fail-over (effectively a distributed database) then maybe. Off the top of my head. You could probably use the routing table from a DHT in some way but it's a big "depends".
