Area within a curve - Green / Kelvin-Stokes Theorem
gyc
Hi there.
I need to compute the area within a closed shape (on XY plane) defined by an array of XY points (XY graph).
Can't find anything for labview related to this. (not using Vision, of course)
"splitting" the curve in two halves, integrating both along the diving (straight ) line and subtracting the resulting areas does not always yield a correct result because the shape may not always perfectly regular (check picture).
Any suggestions?
Edited by gyc
Wat you are describing is the concept of an integral. Rather than sum up a large rectangle (which you don't have), you break up the object into little rectangles and sum those up.
If you already have the coordinates {x_i,y_i}, i=1...N, simple integration by trapezes gives
A=sum_{i=1}^N (x_{i+1}-x_i)*(y_{i+1)+y_i)/2,
identifying N+1 with 1. You can implement that in pure G as well as with mathscript, as you like.
  On 1/12/2017 at 6:34 PM, infinitenothing said:
How accurate do you have to be? Maybe implement your own flood fill? Otherwise, you have to define some sort of point to point interpolation which could be as simple as defining a polygon
Expand
Accurate: not a problem. It depends on how many (x,y) points i have, so I can control that beforehand.
Floodfill: I am not working with images/pixels. (x,y) are actual floating point values in a measurement space.
This is green theorem (which in turn is a particular case of Kelvin-Stokes) but I can't seem to find anything in LV help.
Expand
Exactly, but I find it difficult to 'split' the figure into rectangles.
What I thought of is to split it into triangles, of which one vertex is the center of mass of the figure itself. (good old romans already did that!)
Why arguing? If you have the coordinates you have the analytical solution. You may decompose it in summation of areas of oriented triangles with a common vertex (any point of the plane), or in trapezes based on the y axis, you will get to the same result.
Ensegre, don't you need a convex polygon for that?
Expand
You could convert the vectors to discrete pixels using Bresenham's Algorithm
Expand
No. https://en.wikipedia.org/wiki/Shoelace_formula, http://mathworld.wolfram.com/PolygonArea.html. Just with an alternative arrangement of the terms.
Expand
You could if you want to rasterize your image. Do you need that?
Expand
Not arguing, just learning (always learning).
Excellent implementation, btw!
  On 1/24/2017 at 8:47 PM, GregSands said:
In fact there's Polygon Area.vi in the Mathematics/Geometry/Computational Geometry palette.  Slightly different but equivalent implementation.  Typing "area" into Quick Drop found it immediately
Expand
Doh, completely right. That would be the first of the alternatives given in https://en.wikipedia.org/wiki/Shoelace_formula, plus argument checks. It occurred me to think that among the various alternatives, both the one I thought and this one are the most efficient needing only two array allocations and one multiplication. The determinant form in http://mathworld.wolfram.com/PolygonArea.html needs two.
