How to add a folder to build spec using VI scripting
Gribo
Hello,
I am trying to automate some code generation using a project template. The template also has build specification. I want to add an auto-populating folder to the build specification, but I can't get it to work. I am using the AB_API_SDIST class. If the folder exists in the template, I get an error 'Can't add the container to build specification'. If the folder does not exist in the template, I get a 1055 error code.
How can I make it work?
So are you trying to add a virtual folder under the Build Specifications section of a project?
I've never seen a virtual folder there and I can't seem to add one manually in a LabVIEW project or even drag an existing, empty, virtual folder into build specifications. If LabVIEW is throwing an error that you 'Can't add the container to build specification' I'm guessing it's just not something you can do. I'm also not sure why there would be an auto-populating folder under the build specifications because the build specifications don't have files associated with them.
  • 2 months later...
  • 1 year later...
Ok, thank you
Virtual folders are proving to quite a bit of trouble, simply deleting one from the project can result in labview 2017 crashing (only on Windows 10 it seems)
Edit: and in Windows 7 as well, just seems less likely to happen
Edited by BramJ
  • 4 weeks later...
I was trying to script something involving a build specification just yesterday. I'm pretty sure "Targets" refers to things like "My Computer", not build specifications. You can get a reference to the Build Specifications folder through the "My Computer" property of the project, IIRC. And from there you can get the Owned Items[] property, find the one you need, and use "To More Specific Class" to make it a Build Specification refnum. However, strangely, I haven't found any methods/properties that do anything specific to build specifications. Maybe I'm looking in the wrong place though.
Yeah, I'm not aware of any. The App Builder API (vi.lib\AppBuilder\AB_API) provides most of the functionality you would need to programmatically modify build specs. I talk about it briefly in my Hidden Gems presentation: http://www.ni.com/hiddengems
Taco deli? 😉
Edited by flarn2006
