becktho Posted April 27, 2005 Report Posted April 27, 2005 Hi all Is there anyone who may help me with this problem? Thanks in advance. Thomas Quote
Bryan Posted April 28, 2005 Report Posted April 28, 2005 I can't read german, so I can't get the specifics of the error, but I do know that sometimes if loops aren't properly stopped and references closed before your application exits, you can get errors. For example, with an exe I built, I had a property node (or method, don't remember which) that closed the front panel residing inside of my main while loop. Therefore, the window was closing before the loop exited and I would get an error in the exe when it closed. This only happened on some machines, but not all. I moved it outside the loop and haven't seen it since. Quote
i2dx Posted April 29, 2005 Report Posted April 29, 2005 this is no strange error, its the typical former "bluescreen", now "Read-Exception" Windows error, which happens, if you want to read/write to a memory location which is protected by the OS. i try to translate: The instruction in "0x123456" referenced memory at "0x56789". The memory could not be "read". This happens typically im C++ e.g. by trying to read a private variable by a pointer. Mybe you have open activeX references or stuff like this in your LV programm ? best regards, CB Quote
