dhahmed Posted May 27, 2018 Report Posted May 27, 2018 Hello Lava fellows, I have numeric data of a PV panel (irradiation, temperature, ..) during months in a lot of different txt file. And I want to import this data and analyze it with LabVIEW: Find the higher temperature, display the values of temperature of 5 days during a months, display it in graphs. PLEASE I need your help ! Quote
JKSH Posted May 28, 2018 Report Posted May 28, 2018 3 hours ago, dhahmed said: PLEASE I need your help ! Help us help you. Please provide details on what kind of help you want: Do you want us to: Give you some ideas on how to start? Or review code that you've already written? Or write the code for you? Also, please provide details on how much LabVIEW experience you have and how much general programming experience you have. 1 Quote
_Mike_ Posted May 28, 2018 Report Posted May 28, 2018 That sounds like a perfect task for visualization tool like e.g. grafana: https://grafana.com/ Though if you insist on using LV for that, I'd recommend you to import all different data using "Read Delimited Spreadsheet VI" http://zone.ni.com/reference/en-XX/help/371361P-01/glang/read_delimited_spreadsheet/. Then you should merge the data together into one-format array. Having all the information in one array will allow you to perform whole variety of analysis. 1 Quote
dhahmed Posted May 28, 2018 Author Report Posted May 28, 2018 7 hours ago, JKSH said: Help us help you. Please provide details on what kind of help you want: Do you want us to: Give you some ideas on how to start? Or review code that you've already written? Or write the code for you? Also, please provide details on how much LabVIEW experience you have and how much general programming experience you have. Thank you for your interest, I've began with labview one month ago. And please, I want the code of the programme because I don't have time. Quote
_Mike_ Posted June 1, 2018 Report Posted June 1, 2018 (edited) try this one readmultiformatdata.zip here comes the example of reading three different files, with different formats and different data - then it converts each log file to a common style, and created one joined log. readmultiformatdata.zip Edited June 1, 2018 by _Mike_ Quote
