Labview RGT Error
kaly2002
  •   There are some problems with the labview I installed,The labview RGT Vi about Graphs can't run。
  • The specific issues are in the attached file。I need your help!
Looks like you might have an unsupported excel version? although this says 2016 should be compatible... http://www.ni.com/product-documentation/54029/en/
The fast answer is that you should try to click on each of the broken nodes and see if you can re-select whatever is shown. So for example click on the "chart" node and see if "application" is an option, and so on. I've done this before with "incompatible" versions (eg excel 2016 with report gen 2014, or database toolkit in labview 64-bit) and its worked, but obviously you get no guarantees.
There are also other excel toolkits out there, although I know paying more is not ideal. For example: http://sine.ni.com/nips/cds/view/p/lang/en/nid/212056 see next post
Edited by smithd
XLR8 doesn't depend on having Excel installed at all to work, but it has some major limitations over Excel.  Last I knew graphs and charts weren't supported at all.  It really is just a way to write and read cell data not too much on the fancy formatting side.
