Send email with Thai/ Chinese / Japanese character
15 minutes ago, Benoit said:
I am trying to send email in LabVIEW with Asian character.
What encoding do you use for those characters? LabVIEW's email VIs send emails assuming the UTF-8 encoding (http://zone.ni.com/reference/en-XX/help/371361P-01/lvcomm/smtp_client/ ); you might need to encode your Asian characters in UTF-8 first.
I haven't tried this myself, but you could also try calling the Set Headers VI (http://zone.ni.com/reference/en-XX/help/371361P-01/lvcomm/smtp_set_headers/ ) and set the Content-Type header to match your non-UTF-8 encoding (https://www.emailonacid.com/blog/article/email-development/the_importance_of_content-type_character_encoding_in_html_emails/ ).
Edited by JKSH
I am actually trying to figure out how to use the exact information you proposed to me.
Did you ever succeed? If yes, do you have an example?
i think the formatting of the array with the information to write as input is the problem I have.
Benoit
I just did a quick test. It looks like LabVIEW assumes that the email text is encoded in your PC's default 8-bit encoding. Then, LabVIEW automatically tries to convert the text to UTF-8.
I think this means the only way to send Japanese emails through LabVIEW is to configure your whole PC to use Japanese 8-bit encoding and/or use the Japanese version of LabVIEW. :(
(I'll have to leave for now, sorry. I'll try some more tests tonight to see if anything else works)
16 hours ago, Benoit said:
Sending the email in html format with the following VI to transform Unicode from LabVIEW to HTML character.
I think it will work in most of the case.
Yes, that sounds like a solid solution. Good thinking, and congrats!
