How do I create a folder with a decimal/period?
bmoyer
This seems like it should be easy, but I have not been able to create a folder that has decimal/period using LabVIEW.
For example, creating a folder named "Blah 1.1" yields a folder named "Blah".  I can create the folder directly in Windows so I know it is valid.
Has anyone else seen this before?
Thanks,
Bruce
How specifically are you trying to create the folder?
I'm using LabVIEW 2016 on Windows 7 and just tried creating a folder named "Blah 1.1" on my desktop.  I did it using the "Create Folder" node located in the "File I/O" >> "Adv File Funcs" palette and it worked for me.
If you're using Windows 10 and LV 2017, I'm not sure if one of those could be the culprit.
Edited by Bryan
I think I must have had low glucose at the time (just before lunch).  I should've created a simple example, but it turned out I was missing a input to my VI!  Grrh!  It's working now.
Thanks for your help!
Bruce
