rscott9399 Posted May 1, 2019 Report Posted May 1, 2019 I am trying to reset a Crio 9074 following this procedure https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000000P9Y3SAK&l=en-US However, even in safe mode i cant get by the password. The document says to simply click on. The OK button on mine is greyed out. NI MAX is showing the controller is in safe mode Anyone have any suggestions? Thanks Quote
rscott9399 Posted May 1, 2019 Author Report Posted May 1, 2019 I was able to come up with a solution so this can be closed. Thanks Quote
hooovahh Posted May 1, 2019 Report Posted May 1, 2019 We generally don't close threads on LAVA, even things like this can be useful to others...assuming you have a solution that is worth sharing so someone in a similar situation can find what you did. Quote
rscott9399 Posted May 2, 2019 Author Report Posted May 2, 2019 The procedure would not work with the CRIO just in SAFE mode For some interesting reason i could only format the machine if it was not only in safe mode but also IP RESET mode Just incase someone else has the same issue. Quote
