rscott9399 Posted May 22, 2019 Report Posted May 22, 2019 (edited) I have a need to hit several front panel buttons of a sub vi in sequence. The sub VI houses an event structure that must happen in order to make a certain thing happen. I have a flat sequence structure. that turns off and on local variables that are then fed into the sub VI. The subVI is called in its own while loop. the flat sequence is running and the local variables are changing correctly. However, the subVI in the while loop will not execute causing the event structure inside the subVI to not detect a change and nothing happens The while loop that contains the subvi has no connects in or out of it, its all local variables Any recommendations on how to fix this? Thanks Edited May 22, 2019 by rscott9399 Quote
paul_cardinale Posted May 22, 2019 Report Posted May 22, 2019 I'm pretty sure that you've built your block diagram incorrectly. Just do it right and it will work fine. (Since you didn't provide any code, I can't be more specific than that.) 2 Quote
