rharmon@sandia.gov Posted June 19, 2019 Report Posted June 19, 2019 I'm trying to build a Hex String to send to a piece of equipment... As you can tell by the title... Hex Strings are not my favorite things to work with... The correct output from this vi should be a hex string 0106 012C 05DC 4B36. I don't have a clue where I'm going wrong. Can someone point me in the right direction??? Please.... crc16-2.vi Setpt to String.vi Quote
crossrulz Posted June 19, 2019 Report Posted June 19, 2019 (edited) You are mixing definitions of "Hex String". It appears you need a raw/binary/flat data string. So replace the Number To Hexidecimal String with a Flatten Into String. The Number To Hex String converts into an ASCII text, which you do not want. Further, since you only want 4 hex character (ie 2 bytes), you need to add a U16 conversion bullet after the multiplication. Edited June 19, 2019 by crossrulz Quote
rharmon@sandia.gov Posted June 19, 2019 Author Report Posted June 19, 2019 Thank you... That works perfect... Quote
