Thang Nguyen Posted July 9, 2019 Report Posted July 9, 2019 In my application, I try to change the size of the Front Panel of sub VI based on configuration. I am not sure why I got error below. subVI Set Dialog Size's block diagram When call this VI, I tried to passed in VI server reference or pass using VI property node reference. Both of methods return same error Thank you in advance. Quote
Thang Nguyen Posted July 9, 2019 Author Report Posted July 9, 2019 @ensegre: I am actually aware of the panel limit size. I did set the minimum size to the smallest value I can set to. But after setting it to 1x1, I don't get error anymore. I guess this fixed it. Thank you very much. Quote
