Crash and errors in LV2018 IDE
Hi All
Since few times (14/12/2020) and few addons /plugins/ toolkit and  QD installation, i observe sometime crash and/or error rapport génération when i close LV. Just today 0 crash , but 23 "Dump" in error rapport when i close LV.
Is-there some specialistes who could help me to identify problem source. I send you  today crash rapport to see details.
Thanks
Eric
lvlog.txt
For starters, there are a few DWarns:
c:\nimble\penguin\labview\components\mgcore\trunk\18.0\source\ThEvent.cpp(216) : DWarn 0xECE53844: DestroyPlatformEvent failed with MgErr 42.
e:\builds\penguin\labview\branches\2018\dev\source\typedesc\TDTableCompatibilityHack.cpp(829) : DWarn 0xA0314B81: Accessing invalid index: 700
e:\builds\penguin\labview\branches\2018\dev\source\objmgr\OMLVClasses.cpp(2254) : DWarn 0x7E77990E: OMLVParam::OMLVParam: invalid datatype for "Build IGL"
e:\builds\penguin\labview\branches\2018\dev\source\typedesc\TypeManagerObjects.cpp(818) : DWarn 0x43305D39: chgtosrc on null! VI = [VI "LSD_Example VI.vi" (0x396f46b8)]
e:\builds\penguin\labview\branches\2018\dev\source\UDClass\OMUDClassMutation.cpp(1837) : DWarn 0xEFBFD9AB: Disposing OMUDClass definition [LinkIdentity "StatusHistory.lvclass" [ Poste de travail] even though 5 inflated data instances still reference it.
e:\builds\penguin\labview\branches\2018\dev\source\UDClass\OMUDClassMutation.cpp(1837) : DWarn 0xEFBFD9AB: Disposing OMUDClass definition [LinkIdentity "Delacor_lib_QMH_Message Queue V2.lvclass" [ Poste de travail] even though 1 inflated data instances still reference it.  This will almost certainly cause a crash next time we operate on one o
Here is some information regarding the differences between DWarns and DAborts:
I'd assume that one of the plugin VIs or classes is broken. You can try and clear the compiled object cache to see if that fixes it.
Alternatively uninstall each plugin until the issue disappears. (start with LVOOP Assistant, I remember having issues with it in LV2015).
