maximus Posted July 12, 2005 Report Posted July 12, 2005 Hi, Is there a spell-check which I can use in my LabVIEW programm? (LabVIEW, CIN, dll). And can I use my own libary for it? thank you in advance... Quote
FLX Posted July 13, 2005 Report Posted July 13, 2005 There was an article about a spell check in the LTR Volume 10 Number 4. LabVIEW Technical Resource cheers alex Quote
Rolf Kalbermatter Posted August 12, 2005 Report Posted August 12, 2005 Hi,Is there a spell-check which I can use in my LabVIEW programm? (LabVIEW, CIN, dll). And can I use my own libary for it? thank you in advance... 5282[/snapback] Theoretically you could try to interface to the Microsoft Office spell checker. At some point Microsoft did document how to do this, first by calling directly into the appropriate DLLs and later by interfacing to the Active X interface of this component. I'm not sure about the current status although I would assume that they do not promote it anymore or at least expect you to go into a license agreement with royality payements to be able to do that. Besides if Active X is the only supported interface nowadays expect to run into lots of versionening issues with different spell check libraries from the different Office packages. Quote
Michael Aivaliotis Posted August 23, 2005 Report Posted August 23, 2005 Here's a post from another LAVA member that makes a call to a website to do a spell check. Not your ideal solution but can give you an idea. All you really need is a good word list, then do a match pattern and word length check, right? Not totaly trivial but doable nonetheless. http://forums.lavausergroup.org/index.php?...findpost&p=1292 Quote
