wallage 1 Posted March 22 Report Share Posted March 22 I have a PXI setup with a PXIe-4081 DMM in it. I am trying to capture a current waveform, at 25kHz. For some reason the first 8 seconds of the data capture seem to float, after which the signal stabilizes. Does anyone know the cause, and solution for this problem? below is a snapshot of the data. The DMM is connected in series with a LED load, which is connected to a DUT. Quote Link to post
Gribo 20 Posted March 30 Report Share Posted March 30 Try configuring the DMM to use a single range. If there is an auto range function active, it might explain the waveform. Can you post the circuit? Quote Link to post
wallage 1 Posted April 2 Author Report Share Posted April 2 On 3/30/2021 at 7:11 PM, Gribo said: Try configuring the DMM to use a single range. If there is an auto range function active, it might explain the waveform. Can you post the circuit? i have tried that, with the same result. Quote Link to post
