wallage Posted March 22, 2021 Report Posted March 22, 2021 I have a PXI setup with a PXIe-4081 DMM in it. I am trying to capture a current waveform, at 25kHz. For some reason the first 8 seconds of the data capture seem to float, after which the signal stabilizes. Does anyone know the cause, and solution for this problem? below is a snapshot of the data. The DMM is connected in series with a LED load, which is connected to a DUT. Quote
Gribo Posted March 30, 2021 Report Posted March 30, 2021 Try configuring the DMM to use a single range. If there is an auto range function active, it might explain the waveform. Can you post the circuit? Quote
wallage Posted April 2, 2021 Author Report Posted April 2, 2021 On 3/30/2021 at 7:11 PM, Gribo said: Try configuring the DMM to use a single range. If there is an auto range function active, it might explain the waveform. Can you post the circuit? i have tried that, with the same result. Quote
