How to prevent other's from creating instances from in interface?
I just noticed that I can drag an interface onto block diagram and create an instance of the interface.  But for most of the cases, I want the interface to be abstract.  Is there any way to prevent users from creating instance from the interface I provided?
No you cannot.
Your simplified example, if the interface is truly abstract, is equivalent to trying to prevent someone from dropping a "empty string constant" on the block diagram.
Fundamentally though, it would prevent you from using the direct cast to exercise the override, as shown in the bottom example.
The only restriction is that one cannot create a DVR of the interface from outside the interface itself.
I have to admit that I have not investigated the consequence of such a pattern in the context of interfaces...
The restriction on DVRs is the same for interfaces as for classes: it allows for constructor/destructor notation for by-reference entities. Please don't go hyper excited and think "Oh, this is the tool I should have been using all along." By-reference designs are fragile and prone to several classes of errors that by-value code cannot create. Stick to the wires where possible; use references only when nothing else serves! 🙂 Details here.
  • Like 2
As Francois noted, no, you cannot prevent it. The default instances are useful in many sentinel and error handling situations -- think like NaN in floating point. The defaults can also serve a role similar to "null" but without all the dangers of open references. Details about design decisions of interfaces can be found here.
