System exec. issue.
Hi all,
Im strugeling with the "simple" issue. I call the python script with args via System exec.
If "wait until completion?" is TRUE, its no responding or just reports error. Error is that the script is missing args. If wait until completion? is FALSE, then script work just fine.
Commend line: "python.exe script.py --port com3 --adr 2 file_name.hex"
Im running LV 2019 32bit version.
How do you determine that your script is working? As you don't wait for completion, the error cluster obviously can't indicate anything about the actual execution of the command, only if LabVIEW was able to create the main process.
HI.
Error cluster shows nothing, i meant "standart error output"
Script is upgrading FW on my PLC. I can see LED is togeling, and in the cmd window progress bar is changing during that process. When the process is over i  i can use "standart output" to veryfi the results. it can happend that the FW upgrade need to be repeeted.
Standard error output can't show anything either when you make the wait for completion false. So that would not indicate anything. With wait for completion set to false the process is launched and forgotten by LabVIEW. If it runs a millisecond or infinitely doesn't matter for LabVIEW. It has long continued and that process may still be running, or may have died or normally terminated.
So the only thing that remains is:
Does the LED toggle anyhow and does it show some progress in the command window? If so then the only difference is that with wait for completion set to true LabVIEW will wait for the process to terminate and then copy the standard output and standard error information into the string indicators of that function. With wait for completion set to false LabVIEW will NOT connect the standard input, standard output and standard errors in any way and whatever your program writes to those either is shown on the command window or lost forever in the /dev/null world of computers.
8 hours ago, Daniel Bochen said:
...Error is that the script is missing args. If wait until completion? is FALSE, then script work just fine...
It sounds to me like the error is being generated by the Python script and isn't necessarily the SystemExec VI if it claims to be missing args.  As Rolf said, if you pass it a FALSE for Wait until Completion, LabVIEW will send the command and return immediately - not waiting for the python script to return.
Some things to remember, if your "script.py" or "file_name.hex" is a path or filename that has any spaces in it, you'll have to put the entire path or filename in quotes as I believe arguments are parsed by Python using spaces (Please correct me if I'm wrong, I don't know much about Python.):
python.exe "C:\path\to\script.py" --port com3 --adr 2 "C:\path\to\file_name.hex"
Alternatively, you could try passing the command switch to execute and then terminate:
cmd /C python.exe "C:\path\to\script.py" --port com3 --adr 2 "C:\path\to\file_name.hex"
If your python script is waiting for a response before returning to the command prompt, then SystemExec will hang forever waiting for a response.  In that case you'll have to pass a value to STDIN.
We had an instance of executing an EXE via SystemExec that would wait for a "Press any key to continue" if it had an error and would hang forever waiting for a key press.  Our solution was to pass it a "space" constant for STDIN so that it would return.  Interestingly, it wouldn't return the error via STDERR and did so via STDOUT.
Edited by Bryan
