jpo Posted October 31, 2022 Report Share Posted October 31, 2022 Looking for a example of UI with the main program able to open a floating pop up window which is used to displays a periodiaclly updated chart. All user interactions is done thru the main window and not the chart window. J- Quote Link to comment
ensegre Posted October 31, 2022 Report Share Posted October 31, 2022 I have several, but within bigger applications... Anyway, there are many ways of doing one. The quickest and dirty I can think of is to share the data between main and floating panel via a global variable, to poll periodically the value in the panel, and to trigger a redraw of the chart only when a change between old and current value is detected. Of course this is doesn't scale up very well; for more sophistication you could set up notifiers between the two, transmit only the portion of data which changed. There are several inter-VI communication options, the best one depends on the use case. To make the panel floating and open it pressing a button on from main, etc, VI server FP properties/methods. Quote Link to comment
drjdpowell Posted November 1, 2022 Report Share Posted November 1, 2022 If you just need to display a chart in a window, it's easy to do with a simple subVI. The subVI contains nothing but a chart control attached to a subVI terminal. Call the subVI periodically with new data. Open its Front Panel with a VI Server call. Quote Link to comment
