Youssef Menjour Posted February 3, 2023 Report Posted February 3, 2023 I'm trying to launch a batch with LabVIEW but i have some access restriction. Output of my bat is written in a txt file. When i launch it directly in windows it works. When i try with LabVIEW cmd i have some restriction. Is it possible to make it works with the good cmd ? test.bat my_test.txt Quote
ShaunR Posted February 4, 2023 Report Posted February 4, 2023 Start is an extension. Remove "start" or enable cmd extensions (/e:on). I'm guessing you think the "/x" is enabling extensions. It's not. There is no "/x". Quote
Youssef Menjour Posted February 5, 2023 Author Report Posted February 5, 2023 On 2/4/2023 at 1:44 PM, ShaunR said: Start is an extension. Remove "start" or enable cmd extensions (/e:on). I'm guessing you think the "/x" is enabling extensions. It's not. There is no "/x". I have removed start but bat file does not launch why ? How to launch a bat with LabVIEW cmd ? Quote
ShaunR Posted February 5, 2023 Report Posted February 5, 2023 Have you got a load of spaces before the test.bat string? This works fine. Quote
