Wolfram Posted August 23, 2005 Report Share Posted August 23, 2005 The one case bug with only "False". Download File:post-1013-1124823090.vi Quote Link to comment
Jim Kring Posted August 23, 2005 Report Share Posted August 23, 2005 The one case bug with only "False". 5803[/snapback] This behavior is present in LV 6.1 and still seems to be present in the newest version of LabVIEW. I just filed a bug report with NI. Quote Link to comment
JohnRH Posted August 24, 2005 Report Share Posted August 24, 2005 This behavior is present in LV 6.1 and still seems to be present in the newest version of LabVIEW. I just filed a bug report with NI. 5804[/snapback] Are you checking this bug list against the newest version of LabVIEW very extensivly? Would it be worth coordinating effort to get them all checked out? (I could help, but no sense duplicating effort) Quote Link to comment
m3nth Posted August 24, 2005 Report Share Posted August 24, 2005 Nice. Would you like that to be false? or false? Quote Link to comment
Jim Kring Posted August 24, 2005 Report Share Posted August 24, 2005 Are you checking this bug list against the newest version of LabVIEW very extensivly? Would it be worth coordinating effort to get them all checked out? (I could help, but no sense duplicating effort) 5808[/snapback] John, I have submitted a bug in the LabVIEW Wait beta. Quote Link to comment
JohnRH Posted August 24, 2005 Report Share Posted August 24, 2005 John, I have submitted a bug in the LabVIEW Wait beta. 5819[/snapback] That's the version I was referring to as well. Quote Link to comment
Wolfram Posted August 25, 2005 Author Report Share Posted August 25, 2005 This behavior is present in LV 6.1 and still seems to be present in the newest version of LabVIEW. I just filed a bug report with NI. 5804[/snapback] Another nice case bug. Download File:post-1013-1124973923.vi Quote Link to comment
Jim Kring Posted August 25, 2005 Report Share Posted August 25, 2005 Another nice case bug. 5842[/snapback] I'm not sure if this is a bug. It might just be a feature. I recall a thread on info-labview on this a few years ago. I think that when you are using string ranges, the upper limit is non-inclusive. Quote Link to comment
jpdrolet Posted August 25, 2005 Report Share Posted August 25, 2005 I'm not sure if this is a bug. It might just be a feature. I recall a thread on info-labview on this a few years ago. I think that when you are using string ranges, the upper limit is non-inclusive. 5846[/snapback] It is a bug. The VI should be broken for "no case for some selector values". Quote Link to comment
Jim Kring Posted August 25, 2005 Report Share Posted August 25, 2005 I'm not sure if this is a bug. It might just be a feature. I recall a thread on info-labview on this a few years ago. I think that when you are using string ranges, the upper limit is non-inclusive. 5846[/snapback] It is a bug. The VI should be broken for "no case for some selector values". 5848[/snapback] Jean-Pierre, I was referring to Wolfram's second bug posting, which has a string range frame and a default frame. Quote Link to comment
Wolfram Posted August 30, 2005 Author Report Share Posted August 30, 2005 I'm not sure if this is a bug. It might just be a feature. I recall a thread on info-labview on this a few years ago. I think that when you are using string ranges, the upper limit is non-inclusive. 5846[/snapback] In case structures, you usually have to enter all included values, if the case structure handles integers. For me, this would be a strange feature, if strings are handled differently. So I think this is a bug. Quote Link to comment
Michael Aivaliotis Posted August 31, 2005 Report Share Posted August 31, 2005 The one case bug with only "False". 5803[/snapback] It's interesting how this bug only appears when you delete the TRUE case. If you remove the FALSE case and leave only a TRUE then you get a broken VI which is the expected behavior. Quote Link to comment
jpdrolet Posted August 31, 2005 Report Share Posted August 31, 2005 In case structures, you usually have to enter all included values, if the case structure handles integers. For me, this would be a strange feature, if strings are handled differently. So I think this is a bug. 5893[/snapback] It behaves differently for strings and numbers and I think this is the intended behavior. The difference comes from the fact that strings are variable length objects. If the case for string range were inclusive, the range "a".."z" would match for all strings of any length beginning with "a" to "y" plus the lenght 1 string "z". To match all strings beginning with "a" to "z" you would need to set as the upper range the lexically largest string begining with "z" that is "z Quote Link to comment
B Chavez Posted August 31, 2005 Report Share Posted August 31, 2005 I've come across a problem with a case structure as well. I have a case structure with a string wired to the selector input. There are three cases: "", "Idle" "copy this state" Default When I try to right click the case structure and check "Case Insensitive Match," LabVIEW generates an error and shuts down. Deleting or modifying the cases seems to fix the problem, but this shouldn't happen. I've attached the VI if anyone is interested in trying it. I'd be interested if it doesn't do the same thing on someone elses machine. Download File:post-1591-1125504444.vi Quote Link to comment
Louis Manfredi Posted August 31, 2005 Report Share Posted August 31, 2005 I've attached the VI if anyone is interested in trying it. I'd be interested if it doesn't do the same thing on someone elses machine. 5927[/snapback] Hi B. Same thing happens to me, LV 7.1.1, Windows XP SP2 Dell Latitude M60. Best Luck, Louis Quote Link to comment
BChandler Posted September 10, 2005 Report Share Posted September 10, 2005 It's interesting how this bug only appears when you delete the TRUE case. If you remove the FALSE case and leave only a TRUE then you get a broken VI which is the expected behavior. 5912[/snapback] Also if you retype the False label, it becomes broken. (at least in LV 6.1) Seems the error check is in there , just doesn't run right after deleting True. Quote Link to comment
