Ramya JM Posted February 28, 2023 Report Posted February 28, 2023 Main Package Name: NI Biomedical Toolkit v15.0.0.15 Package Name with Error: NI Biomedical Toolkit v15.0.0.15 Error Message: VIPM could not install the package national_instruments_lib_ni_biomedical_toolkit-15.0.0.15 . Error Code: 42 Error Source: PreInstall.vi<ERR> This package requires administrative privileges to install. Please restart VIPM and LabVIEW as an Administrator to continue installation. Quote
ShaunR Posted February 28, 2023 Report Posted February 28, 2023 How to overcome this error? By doing what the error messages says. 1 Quote
Ramya JM Posted March 1, 2023 Author Report Posted March 1, 2023 Tried to install biomedical toolkit from VI package manager Quote
MichaelBalzer Posted March 1, 2023 Report Posted March 1, 2023 On 3/1/2023 at 5:27 AM, Ramya JM said: Tried to install biomedical toolkit from VI package manager Expand Exit LabVIEW and VIPM, then run VIPM as administrator, then install the Biomedical toolkit. If you're running LabVIEW 64-bit, you'll also need to update one of the toolkit's dll files. The toolkit states it supports LabVIEW 64-bit, but the bundled LVDICOM.dll file is 32-bit only. There is a 64-bit version of the dll available on the NI forums, which will need to be copied over the 32-bit version found in C:\Program Files\National Instruments\LabVIEW <version>\resource Quote
