String message parse optimization - the game
Your task is whipping up a piece of code that can unravel a string stuffed with uint64 data, all dressed up in that fancy communication protocol jacket. But hold your horses, partner! The catch is to make it faster than my own fancy footwork. Giddy up and get coding!
Example of slow solution:
Much faster solution:
Y'all can lay your eyes on the testin' stuff right down yonder in that there attachment. And guess what? There's a little description of that frame thingamajig to tickle your fancy. So put on your explorin' hat and give it a gander!
decode-frame.viFetching info...
Edited by Łukasz
  • Haha 1
I tried all the solutions using LabVIEW 64-bit on Ubuntu. I fixed case 2, and cases 5 and 6 produced very similar results. I'm a bit worried about using BLAS VIs because they might cause problems during the building process.
@cordm and @LogMAN I truly want to express my gratitude for your help.
