Bjarne Joergensen Posted November 2, 2023 Report Posted November 2, 2023 Hi I got a problem with my mouser curser. It does not change style when hovering over objects. It is always an arrow. If I open the Tool box window, I can see it's changing to another tool when hovering, but the curser don't. It's only observed at one PC. I have tried to repair LabVIEW. Using LV2019 Windows 10 I control the PC via TeamViewer (but I also have a similar PC controlled via TeamViewer that don't have this problem). /Bjarne Quote
ShaunR Posted November 2, 2023 Report Posted November 2, 2023 (edited) Looks like you have a custom theme in Windows where the cursor is defined. If you look, it changes from a left-pointing arrow to a right pointing arrow. Edited November 2, 2023 by ShaunR Quote
Bjarne Joergensen Posted November 2, 2023 Author Report Posted November 2, 2023 Hi ShaunR The curser on the picture is one I have drawn! When you make a "PrtSC" the curser don't get copied ;( Quote
Bjarne Joergensen Posted November 3, 2023 Author Report Posted November 3, 2023 Hi I have found out that it's not only a problem in LabVIEW, but in windows and all applications. regards Bjarne Quote
