rgrunwell Posted September 16, 2005 Report Posted September 16, 2005 I use case structures as part of state machines, and with large programs having many states, it becomes difficult to distinguish sections of related states. Some sort of delineation, user configurable but functionally invisible, would help organize and break up an otherwise unfathomable list. Possible implementations could be as simple as being able to insert a line between entries. Other possibilities could be the setting of the background behind the case text, the text color, or the text style. Quote
Jim Kring Posted September 16, 2005 Report Posted September 16, 2005 You can achieve this by adding no-op frames that are titled "------------ Section Name ------------". They are not intended to be executed, but rather serve as deviders between groupings of frames. Quote
PJM_labview Posted September 16, 2005 Author Report Posted September 16, 2005 You can achieve this by adding no-op frames that are titled "------------ Section Name ------------". They are not intended to be executed, but rather serve as deviders between groupings of frames. And they are a very usefull starting point for adding a new frame to this section (expansion). PJM Quote
PJS Posted October 11, 2005 Report Posted October 11, 2005 You can achieve this by adding no-op frames that are titled "------------ Section Name ------------". They are not intended to be executed, but rather serve as deviders between groupings of frames. The only issue here is that they have to be different for every divider. Not a major big deal, but there non the less, plus tunnels need to be addressed. I frequently turn off the default if unwired to keep me from making an oops. With various state machine architectures, this should be a feature available in the state case similar to the custom menu dividers. Quote
