compiling as shared library fails (err 42)
Antoine Chalons
We have a LabVIEW 2020 SP1 project on Linux that compiles well on Ubuntu 20 (not officially supported)
We compile as an application and also as a shared library
We use the application (with UI) for test and debug and in production we run the shared library as a service
We do not use any DAQ or any other NI driver
We moved to CentOS 8 (officially supported), fresh install of LabVIEW 2020 SP1 and here the application compiles well but the compiling as a shared library fails, the compilation process runs till the end (or seems to) and then returns the following error :
Error 42 occurred at System Exec.vi. Command was "gcc -m64 -shared -g  -O2 -fPIC -Wl,-Bsymbolic -I/usr/local/natinst/LabVIEW-2020-64/cintools "synchrohub.c" /usr/local/natinst/LabVIEW-2020-64/AppLibs/lvdll.a  -o "synchrohub.so" -lstdc++ -ldl"
Any one has any idea what the issue could be?
cross-posted to NI forum
Edited by Antoine Chalons
add link to NIF post
  • Antoine Chalons changed the title to compiling as shared library fails (err 42)
it appears that the system exec.vi just doesn't work, even in the IDE
and therefore fails when the build process calls it
as shown below, the system exec.vi is runnable but fails with error 42, whatever cmd I try to run
I don't know if this helps in any way, but I wanted to see if I would see similar behavior with LabVIEW 2021SP1 CE on my Linux Mint 21 installation - and I did not.
You had mentioned that you were using LabVIEW 2020 (Not officially supported).  Does your circumstances prohibit you from moving to a supported version of LabVIEW?
If I think about it later today, I'll do this same thing on a Zorin16/LabVIEW2018 VM that I have running at work to see if I see the behavior there.  I don't know if it contributes anything other than another data point.
Thanks for trying!
I did try with LabVIEW 2022 and get the same result on CentOS 8
On Ubuntu 20 I never had this issue with LabVIEW 2020 SP1 or 2022
Also I saw this old post from Mickael who had a similar issue back in 2014 :
and interestingly, on the second start of LabVIEW 2022, the system exec.vi works BUT compiling still fails with the same feedback :(
