CIPLEO Posted February 1, 2024 Report Posted February 1, 2024 Hello, I wanted to make an executable that would build a project using the LabVIEW VIs found in : C:\Program Files\National Instruments\LabVIEW 2020\vi.lib\AppBuilder\AB_API\Build However, I get error 7 when I run my executable. Get LV Class Default Value.vi<APPEND> <b>Complete call chain:</b> Get LV Class Default Value.vi AB_API Factory.vi NI_AB_API_Build.lvclass:Open Build.vi test_build_for_exe.vi <b>LabVIEW attempted to load the class at this path:</b> C:\Users\xxxxx\Desktop\builds\vi.lib\AppBuilder\AB_API\EXE\NI_AB_API_EXE.lvclass. After some research ( https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019O6PSAU&l=fr-FR ) I saw that the classes should be put in the "Always Included" section. However, the classes my VI uses are in my project's dependencies, so I can't include them. How can I include classes that are in a project's dependencies when creating an executable? See you soon Quote
Darren Posted February 1, 2024 Report Posted February 1, 2024 The App Builder API is not supported within a built EXE. It can only run in the LabVIEW editor. More generally, there is no way to build a LabVIEW EXE that can build LabVIEW EXEs. Quote
Antoine Chalons Posted February 2, 2024 Report Posted February 2, 2024 Well.. not directly, but a LabVIEW built EXE can script the LabVIEW IDE to build an EXE. Of course you need a computer with LabVIEW IDE installed & a valid licence that includes App builder. Quote
CIPLEO Posted February 2, 2024 Author Report Posted February 2, 2024 I'll try the script, thanks. Thank you for your replies. Quote
Rolf Kalbermatter Posted February 2, 2024 Report Posted February 2, 2024 On 2/1/2024 at 5:08 PM, Darren said: The App Builder API is not supported within a built EXE. It can only run in the LabVIEW editor. More generally, there is no way to build a LabVIEW EXE that can build LabVIEW EXEs. Expand That's technically not exactly correct since there exists something like lvrtff. However trying to use that in order to be able to build LabVIEW applications from within a LabVIEW application is definitely not worth the hassles. Quote
