alphaone Posted October 11, 2005 Report Posted October 11, 2005 Hi, I set a breakpoint on outer frame of the Sequence .and it can not be deleted! There is always a red rectangle on the frame!! Somebody helps me. Quote
Yair Posted October 11, 2005 Report Posted October 11, 2005 Hi, I set a breakpoint on outer frame of the Sequence .and it can not be deleted!There is always a red rectangle on the frame!! Somebody helps me. To clear a brekpoint on the outer frame, you usually need to click on the border of the structure itself. If this doesn't help, for some reason, you can right click and remove the sequence and then rebuild it. Quote
alphaone Posted October 11, 2005 Author Report Posted October 11, 2005 To clear a brekpoint on the outer frame, you usually need to click on the border of the structure itself. If this doesn't help, for some reason, you can right click and remove the sequence and then rebuild it. But this sequence is so big and many registers connected into it.it's impossible to rebuild it. Quote
Louis Manfredi Posted October 11, 2005 Report Posted October 11, 2005 Hi Alphaone: As Yen says, you should be able to clear the breakpoint by clicking on the outer edge of the frame with the breakpoint tool. And ususally this works for me... But If I set the breakpoint, then turn off debugging in the "vi properties... executuion" panel, the breakpoint stays set (or at least the red rectangle stays there) and can not be cleared. Turning on debugging in vi properties let me again turn off the breakpoint. (Seems like a bug to me... the breakpoint ought to go away automatically when you turn off debugging, but perhaps there's a good reason for it to stay, haven't looked closely at this.) Anyway, Hope I've helped a little. Best Regards, Louis Quote
Khalid Posted October 11, 2005 Report Posted October 11, 2005 It will be nice to have a "Clear All Breakpoints" feature (from the menu). Just like MS Visual Studio, for instance. -Khalid Quote
crelf Posted October 11, 2005 Report Posted October 11, 2005 It will be nice to have a "Clear All Breakpoints" feature (from the menu). Just like MS Visual Studio, for instance.-Khalid I don't think I'd use a "Clear All Breakpoints" function - I use breakpoints for a reason (debugging code), and I'd like all my co-developers to have to clear them manually after they've assesed that the code has been properly debugged... Quote
Khalid Posted October 11, 2005 Report Posted October 11, 2005 I don't think I'd use a "Clear All Breakpoints" function - I use breakpoints for a reason (debugging code), and I'd like all my co-developers to have to clear them manually after they've assesed that the code has been properly debugged... I beg to differ. Case in point: we're happily debugging and adding breakpoints left-n-right as we go. We finally find and fix the problem. At this stage, I shouldn't have to go to each breakpoint -- some of which I don't even remember where I put them (may be in a false case which doesn't get exercised under normal operation, for instance) and clear them manually. -Khalid Quote
Yair Posted October 11, 2005 Report Posted October 11, 2005 At this stage, I shouldn't have to go to each breakpoint -- some of which I don't even remember where I put them At least that part can be handled by letting LV find the BPs for you using the Edit>Find option. Quote
alphaone Posted October 12, 2005 Author Report Posted October 12, 2005 At least that part can be handled by letting LV find the BPs for you using the Edit>Find option. Nothing ,LV can not find anything...... Quote
Michael Aivaliotis Posted October 12, 2005 Report Posted October 12, 2005 Nothing ,LV can not find anything......This is fishy. If there is a breakpoint then LV will find it. Can you send the VI or a picture of it? I have a hard time believing this. Quote
alphaone Posted October 12, 2005 Author Report Posted October 12, 2005 This is fishy. If there is a breakpoint then LV will find it. Can you send the VI or a picture of it? I have a hard time believing this. ok,the attachment is the strange BP vi.i delete the non-relative parts. i hope that's not a bug. good luck. Download File:post-2988-1129107011.vi Quote
Michael Aivaliotis Posted October 12, 2005 Report Posted October 12, 2005 ok,the attachment is the strange BP vi.i delete the non-relative parts.i hope that's not a bug. good luck. Well I'll be a monkey's uncle! We have a bonafide bug... Quote
alphaone Posted October 12, 2005 Author Report Posted October 12, 2005 Well I'll be a monkey's uncle! We have a bonafide bug... ohhhhhh. i don't understand the meaning of "bonafide", i can't find it in my translation software. lol i have another question : how to use the VI refnum programtically??as we know, we must select a vi server manuelly ,and i want to use vi path as a parameter to set the vi refnum when the program is running.Can it work?? Thanks. Quote
WMassey Posted October 12, 2005 Report Posted October 12, 2005 ok,the attachment is the strange BP vi.i delete the non-relative parts.i hope that's not a bug. good luck. I don't know if it will work for you with the original code but I was able to get the breakpoint to go away when I right-clicked the flat sequence and then selected "replace with stacked sequence". It remained gone after converting it back to a flat sequence the same way. Quote
Louis Manfredi Posted October 12, 2005 Report Posted October 12, 2005 ohhhhhh. i don't understand the meaning of "bonafide", i can't find it in my translation software. bonafide=genuine. Best Regards, Louis Quote
alphaone Posted October 13, 2005 Author Report Posted October 13, 2005 I don't know if it will work for you with the original code but I was able to get the breakpoint to go away when I right-clicked the flat sequence and then selected "replace with stacked sequence". It remained gone after converting it back to a flat sequence the same way. Thanks, it works. but i must re-arrange the layout. Quote
hukee Posted October 13, 2005 Report Posted October 13, 2005 Hi, I set a breakpoint on outer frame of the Sequence .and it can not be deleted!There is always a red rectangle on the frame!! Somebody helps me. In general, I replace flat sequence with a state machine patten. Quote
crelf Posted October 19, 2005 Report Posted October 19, 2005 I beg to differ. Case in point: we're happily debugging and adding breakpoints left-n-right as we go. We finally find and fix the problem. At this stage, I shouldn't have to go to each breakpoint -- some of which I don't even remember where I put them (may be in a false case which doesn't get exercised under normal operation, for instance) and clear them manually. -Khalid I understand your situation, but using this function could just as easily clear a breakpoint in an area that yo're not working. Also, if you're in a multi-developer team then you could be clearing breakpoints put in by other coders that you're not even aware of. I just think that you'll have to be careful when using this tool - it's like hitting ctrl+B to delete all broken wires: sure, you'll get your unbroken run button back, but you could be doing a whole lotta damage without even knowing it (and with no indiscation that you've done it) Quote
Khalid Posted October 19, 2005 Report Posted October 19, 2005 ... Also, if you're in a multi-developer team then you could be clearing breakpoints put in by other coders that you're not even aware of. ... I agree we have to be careful. However, I am not sure checking-in code with breakpoints is a good practice -- especially on multi-developer projects. IMHO, the scope of debugging should be local to each developer, and thus only the individual's VIs should have the breakpoints she wants (clearing them before checking-in). Imagine hitting breakpoints in places we least expect (and care!). It's like when people check-in broken VIs on a multi-developer project -- well not as bad, but still intrusive. But I guess that's a topic for another discussion Regards, -Khalid Quote
