Khalid Posted October 12, 2005 Report Share Posted October 12, 2005 It will be nice to have a "Clear All Breakpoints" feature (from the menu + shortcut). Just like MS Visual Studio, for instance: http://msdn.microsoft.com/library/default....breakpoints.asp As of now (7.1.1), we have to do a "Find" on Breakpoints and manually clear them one-by-one. -Khalid Quote Link to comment
lavezza Posted October 12, 2005 Report Share Posted October 12, 2005 It will be nice to have a "Clear All Breakpoints" feature (from the menu + shortcut). Just like MS Visual Studio, for instance: http://msdn.microsoft.com/library/default....breakpoints.asp As of now (7.1.1), we have to do a "Find" on Breakpoints and manually clear them one-by-one. -Khalid Try adding this VI to your Project folder in LabVIEW (c:\program files\national instruments\labview 7.1\project). Restart LabVIEW and you will have "Remove All Breakpoints..." in the Tools menu of your VI. Download File:post-192-1129153762.vi Quote Link to comment
Neville D Posted October 18, 2005 Report Share Posted October 18, 2005 Try adding this VI to your Project folder in LabVIEW (c:\program files\national instruments\labview 7.1\project). Restart LabVIEW and you will have "Remove All Breakpoints..." in the Tools menu of your VI. Hi Khalid, and Lavezza, I took the liberty of adding Lavezza's code with a few mods to an existing tool that I had worked on with E. Blasberg. It helps you to find used and unused VI's in a project, kill unused VI's that you select, and now, remove all breakpoints in the project. Throw this llb in your /projects folder and then restart LV. Use from the Tools menu (Find used & unused VI's) Thanks to all who participated. Here it is! Neville Download File:post-2680-1129654122.llb Quote Link to comment
Khalid Posted October 19, 2005 Author Report Share Posted October 19, 2005 Hi Neville, and Lavezza, Thank you for sharing the little utilities. They'll definitely come in handy. I quickly modified Lavezza's VI to either clear breakpoints from all VIs in memory or from just the one it was invoked from. NOTE that it doesn't save the VI(s) so the breakpoints will come back when the VI(s) are reloaded. Thank you, -Khalid Download File:post-311-1129734474.vi Quote Link to comment
Neville D Posted October 20, 2005 Report Share Posted October 20, 2005 NOTE that it doesn't save the VI(s) so the breakpoints will come back when the VI(s) are reloaded. Thank you, -Khalid Hi Khalid, I realized that, and my utility will save the changed VI by invoking the "Save instrument" method. Try it out! Regards, Neville Quote Link to comment
