seoul Posted December 2, 2005 Report Posted December 2, 2005 how can i put a picture to my front panel? I mean, let the picture displayed on my front panel. :headbang: Quote
Adnan Posted December 2, 2005 Report Posted December 2, 2005 Which kind of picture do you mean? If it is a image file, just copy/paste your image file to front panel and save your vi. If you mean using picture toolkit, you must load your image file via "Picture ToolKit/Read XXX File.vi" (where XXX is File Type) to a Picture Control. And then, Right-click on the Picture control, Data Operation>>Make Current Value Default and save the vi, to make it persistent. Quote
pallen Posted December 2, 2005 Report Posted December 2, 2005 You can also just drag and drop image files from Windows Explorer onto your front panel. Quote
Mike Ashe Posted December 5, 2005 Report Posted December 5, 2005 If you search DevZone at www.ni.com you should find some example VIs already written that will do this. Quote
Ashutosh Posted December 16, 2005 Report Posted December 16, 2005 how can i put a picture to my front panel? I mean, let the picture displayed on my front panel. :headbang: Hi You can just copy the picture and paste it on front panel. Also you can Go to Front Panel --> Edit --> Insert Pictire from file --> Choose the picture............... These two options will suffise your purpose. Regards Ashutosh C Quote
