nicB Posted January 22, 2006 Report Posted January 22, 2006 Hi, guy I'm try to installa a labview 8 on linux Suse 10.0 I'm new of Linux, i would like evaluate the difference of windows or linux version. The first problem is: The port in e out vi for access I/O port, exists on linux? Is the problem the not work with a dll's? I want work with the serial e lpt port on labview & linux direct to access in the memory location or pin control. How is possible? Thank's for answer, Nic Quote
Rolf Kalbermatter Posted February 1, 2006 Report Posted February 1, 2006 Hi, guyI'm try to installa a labview 8 on linux Suse 10.0 I'm new of Linux, i would like evaluate the difference of windows or linux version. The first problem is: The port in e out vi for access I/O port, exists on linux? Is the problem the not work with a dll's? I want work with the serial e lpt port on labview & linux direct to access in the memory location or pin control. Not easily. Linux just as Windows does not allow applications to access hardware directly. In Windows you have to write a device driver that does run in the kernel context to do that for you and that is the same for Linux. For Windows there exist several solutions with according device drivers to access the IO adres range from an application level. For Linux there are also several possibilities but an according kernel driver has never made it into the official kernel sources and definitely never will make it into it, since this is a potential security risk. The only way to get that done is by looking for one of the various hacks for Linux port IO access on internet and put that yourself into your kernel. This obviously will require you to at least compile some stuff like a kernel module but more likely to compile your own kernel. Basically while it sometimes seems necessary to do direct port IO it is mostly a bad idea and a potential security risk for sure. Rolf Kalbermatter Quote
i2dx Posted February 2, 2006 Report Posted February 2, 2006 Is the problem the not work with a dll's? there is no problem. a windows dll will simply not work on linux. but if you have the source code, you can compile it as a *.so module yourself ... (dont ask for more, that's all i know about that topic ) Quote
nicB Posted February 3, 2006 Author Report Posted February 3, 2006 Thank for all, On conclusion i will try to find a sourc code on C wich access the port, i compile on linux and i join this with a cin node? Is correct thats? Thank you for all reply. Nic Quote
Rolf Kalbermatter Posted February 8, 2006 Report Posted February 8, 2006 Thank for all,On conclusion i will try to find a sourc code on C wich access the port, i compile on linux and i join this with a cin node? Is correct thats? Thank you for all reply. Nic This won't work. The CIN node or shared library is still running in the application context and as such has no direct access to the protected kernel resources to whom the Port IO adresses belong. You have to extend your kernel itself to allow port access either by a port IO kernel driver that translates your port access requests to the actual hardware access on behalf of your application or by an expansion to the kernel with a system call to manipulate the IO permission map. In the first case you call your device driver and pass it the IO adress, access mode and data and it does then do the actual port read or write for you and in the second case you do a system call to that new kernel function to tell it to modify the port IO permission map for your process to allow direct access to specific IO adresses from your application process. Rolf Kalbermatter Quote
nicB Posted February 11, 2006 Author Report Posted February 11, 2006 This won't work. Thank's , it's clear. I will work on parallel and serial on Labview/linux application, but i'm very far away, to the goal. I hope to find example, but now it not arrive. I will to study how linux work. Thank's all for suggestions. Nic Quote
