Mass Compile and Subviersion
Hi all,
When I try to MassCompile directory under Subversion control LabView try to Mass Compile FOOBAR.vi.svn-base file in .svn subdirectory.
This spent a lot of time and it isn't exactly what I want to do...
It is posible to set some MassCompile Option to force ignore .svd directory ??
Thanks a lot,
Vladimir
I dont think you can do that, but if you are using TortoiseSVN here is a work around (which may not be any faster).
1) Use the export function (right click over your folder>TortoisSVN>Export...) to export the whole directory structure to another folder (the svn folder are not exported)
2) Mass compile this new folder
3) Copy back (manually) the mass compiled files to the original folder under source control
4) Commit your changes
Note: If I were you I would be very carefull not to do anything to these files in the .svn folder. You might end up damaging your repository.
Good luck
PJM
  Vladimir said:
Hi all,
Thanks a lot,
Vladimir
You might try installing TortoiseSVN with the .Net Hack option, which can be selected during installation and causes the .svn folders to be named as _svn instead. This might (I have not tested it), cause the mass compile utility to ignore the _svn folders -- there are several instances where LabVIEW ignores folders and files whose names begin with an underscore.
I have tried this manually, by renaming .svn to _svn, but with no effect.
If this is a problem you face often, you might be able to write your own Mass Compile GUI.
I would:
1) rename the top-level directory (Project -> #Project#)
2) create a new Project folder
3) Recursively move folders and files from #Project# to Project, but leave out the .svn folders
4) Do a mass compile with an Application Invoke node pointing to Project
5) ?? Move the .svn folders to Project (will SVN rebuid those folders? I don't know. I used SVN at my old job, but haven't played with it in over a year)
6) Delete #Project#
I think this would work. SVN would see all your VIs as being changed, but that happens no matter what.
Pat
  • 5 months later...
Here's how I handled it..
Open file Explorer and right click on the root diretory that you want to mass compile, then search for "*.svn.".
Zip up all of those .svn directories. Winzip has a function to "Save full path info". Be sure this is checked.
Now delete all of the .svn directories in the Search Results window.
Do the mass compile.
Last, unzip the all of the .svn directories back to their respective paths.
-James
