Ulrich Posted January 20, 2006 Report Posted January 20, 2006 Hello, I made an .exe file in LV8.0 (PDS). On the PC where LV is installed the programm is running. On another PC without LV, the .exe file will not start because of "lvanlys.dll is an forbidden Labview file" (needed in mean.vi). The lvanlys.dll is in the same directory as on my "Labview" PC. Can anyone help me with this??? Many thanks in advance Ulrich Quote
Neville D Posted January 20, 2006 Report Posted January 20, 2006 Hello,I made an .exe file in LV8.0 (PDS). On the PC where LV is installed the programm is running. On another PC without LV, the .exe file will not start because of "lvanlys.dll is an forbidden Labview file" (needed in mean.vi). The lvanlys.dll is in the same directory as on my "Labview" PC. Can anyone help me with this??? Many thanks in advance Ulrich You need to build the exe making sure to include the analysis functions before starting the build. In the past to get past this rather annoying error, I have just written my own Mean.vi like so: NevilleDownload File:post-2680-1137789746.vi Quote
m3nth Posted January 27, 2006 Report Posted January 27, 2006 You need to build the exe making sure to include the analysis functions before starting the build. In the past to get past this rather annoying error, I have just written my own Mean.vi like so:NevilleDownload File:post-2680-1137789746.vi ...and doing your own mean is actually faster than calling the LabVIEW dll... I can't remember who posted that awhile ago... put them in a high-count loop for comparison. Quote
AnalogKid2DigitalMan Posted January 27, 2006 Report Posted January 27, 2006 m3nth: You 'mean' this thread? http://forums.lavausergroup.org/index.php?showtopic=2282 Quote
m3nth Posted January 30, 2006 Report Posted January 30, 2006 Yup that's it... thanks for posting the link. Quote
Ulrich Posted January 31, 2006 Author Report Posted January 31, 2006 Yup that's it... thanks for posting the link. Hello all together, With LV 7.1 I didn't had this problem. There it was enough to copy the LV run time files to the PC. Actually I have 4 programs as LV8.0 EXE files. 3 of them are running (they don't use this dll) with only copying the run time files. NI recommended to make an installer. With this installer also the program with the dll is running. Unfortunately I have to install everything (also programs I'm not using). LV runtime, MAX, NI488.2, NI Visa, NI Spy. (I need the lvanlys.dll also for linear fit, so I have to use this dll) thanks for your help Ulrich Quote
Rolf Kalbermatter Posted February 2, 2006 Report Posted February 2, 2006 Hello all together,With LV 7.1 I didn't had this problem. There it was enough to copy the LV run time files to the PC. Actually I have 4 programs as LV8.0 EXE files. 3 of them are running (they don't use this dll) with only copying the run time files. NI recommended to make an installer. With this installer also the program with the dll is running. Unfortunately I have to install everything (also programs I'm not using). LV runtime, MAX, NI488.2, NI Visa, NI Spy. (I need the lvanlys.dll also for linear fit, so I have to use this dll) thanks for your help Ulrich I think you messed up your LabVIEW version. Up until LabVIEW 7.0 the lvanlys.dll was a self contained DLL you could easily move together with your labview files. In LabVIEW 7.1 they changed that library to use the Intel Math Kernel Library instead for the number crunching work. This is actually a quite useful move since the MKL is a recognized standard about how to do numerical analysis. However the MKL is not part of LabVIEW and comes with its own installer that does some registry settings so lvanlys.dll can find it. In order for MKL to be properly installed and for lvanlys.dll to find it you have to install it. You can do so by creating an installer in the Application Builder and going into the Installer Settings tab->Advanced... button. Make sure you enable "LabVIEW Runtime-Engine" and "Analyze VIs Support". Other things are usually not really necessary but that of course depends on your application. Now you can just run that installer on any computer and you should get with a proper installation of your LabVIEW executable AND the LabVIEW runtime AND the MKL. Rolf Kalbermatter Quote
Ulrich Posted March 7, 2006 Author Report Posted March 7, 2006 I think you messed up your LabVIEW version. Up until LabVIEW 7.0 the lvanlys.dll was a self contained DLL you could easily move together with your labview files. In LabVIEW 7.1 they changed that library to use the Intel Math Kernel Library instead for the number crunching work. This is actually a quite useful move since the MKL is a recognized standard about how to do numerical analysis.However the MKL is not part of LabVIEW and comes with its own installer that does some registry settings so lvanlys.dll can find it. In order for MKL to be properly installed and for lvanlys.dll to find it you have to install it. You can do so by creating an installer in the Application Builder and going into the Installer Settings tab->Advanced... button. Make sure you enable "LabVIEW Runtime-Engine" and "Analyze VIs Support". Other things are usually not really necessary but that of course depends on your application. Now you can just run that installer on any computer and you should get with a proper installation of your LabVIEW executable AND the LabVIEW runtime AND the MKL. Rolf Kalbermatter Hello all, a colleague of mine found a solution for the problem. He took the lvanlys.dll from LV6.1 and everything is working fine again. have a nice day Ulrich :thumbup: Quote
Rolf Kalbermatter Posted March 9, 2006 Report Posted March 9, 2006 Hello all,a colleague of mine found a solution for the problem. He took the lvanlys.dll from LV6.1 and everything is working fine again. have a nice day Ulrich :thumbup: That of course works if you use the standard analysis functions that were already available in earlier LabVIEW versions and as long as NI didn't change the actual function call itself. It won't work for newer analysis functions added in the latest LabVIEW releases or functions where NI added an extra parameter to support new behaviour. As mentioned just for a Mean calculation doing it in LabVIEW is actually faster, and avoids the external DLL/shared library ;-) Rolf Kalbermatter Quote
