pesce Posted May 19, 2006 Report Posted May 19, 2006 Hallo I need and help to solve this problem: I Quote
Gary Rubin Posted May 19, 2006 Report Posted May 19, 2006 What kind of values do you have for X1 and X2? Can you provide a code snippet? Quote
Gary Rubin Posted May 19, 2006 Report Posted May 19, 2006 The data should be dbl 64bit I would just suggest replacing your formula node with this subvi Download File:post-4344-1148048856.vi Quote
mross Posted May 19, 2006 Report Posted May 19, 2006 The data should be dbl 64bit Sorry, I can't see that anything is wrong. Your vi is hard to read with lines on top of lines. Maybe we both just can't tell what is wired where. Quote
peteski Posted May 19, 2006 Report Posted May 19, 2006 pesce, Looking at your diagram and reading your problem, I'm just about willing to bet that your "FBC" indicator is not really connected to the "fbc" output of the formula node, but is really just connected to your "x2" input of the formula node. If this is the case, it is obscured by the path of the wire being "underneath" the formula node. Try double clicking on the wire leading to your "FBC" indicator and the outline of where the wire "really" leads to should become apparent. Just a guess, -Pete Liiva Quote
pesce Posted May 19, 2006 Author Report Posted May 19, 2006 At the moment I'm at home and I can't check the VI you gave me, but I'll do it as soon as i come back to work. I know the picture is bad ad the wires look bad but trust me the are correct. I can add just a thing the program load a data from a file where i save them in form of spreadsheet file and before i save them i converted them to engineer number may be them problem is in the format but why only for the division? thank you Quote
mross Posted May 19, 2006 Report Posted May 19, 2006 At the moment I'm at home and I can't check the VI you gave me, but I'll do it as soon as i come back to work. I know the picture is bad ad the wires look bad but trust me the are correct. I can add just a thing the program load a data from a file where i save them in form of spreadsheet file and before i save them i converted them to engineer number may be them problem is in the format but why only for the division? thank you If you look at the image I posted you can see it does the same calculation properly using a formula just like yours. The only way yours could not do it right is if the wires are wrong. Check them and be neater next time. You will save everyone a lot of trouble if you pick that habit. Quote
pesce Posted May 19, 2006 Author Report Posted May 19, 2006 I saw your picture, I did my VI a lot of time in different way but the problem is still the division. I take the variable mca also for another calculation where there no other variable and i don't have problem. Thank u for your help! I wish too solve the problem Have good week end! Quote
pesce Posted May 22, 2006 Author Report Posted May 22, 2006 Hallo everybody, As it's monday I'm back to work and I can send you the VI with the data I use to load. I dysplayed in the front pannel the result of division, x*y and x+y and the only problem comes from the division, I wish someone can understand the problem, Thank you very much pesce Download File:post-4969-1148283155.txt Download File:post-4969-1148283188.vi Quote
Gary Rubin Posted May 22, 2006 Report Posted May 22, 2006 Hallo everybody,As it's monday I'm back to work and I can send you the VI with the data I use to load. I dysplayed in the front pannel the result of division, x*y and x+y and the only problem comes from the division, I wish someone can understand the problem, Thank you very much pesce At the risk of sounding dense, what's the problem? Using my hand calculator and the CS and Capacitance values, I get the same answer as your code. The quotient is very close to the CS value, but it doesn't seem that there's anything wrong with the division. Quote
jpdrolet Posted May 22, 2006 Report Posted May 22, 2006 Hallo everybody,As it's monday I'm back to work and I can send you the VI with the data I use to load. I dysplayed in the front pannel the result of division, x*y and x+y and the only problem comes from the division, I wish someone can understand the problem, Thank you very much pesce That VI works. You should have posted the VI with the formula node that doesn't work. Please help us to help you. Quote
