adam85 Posted June 15, 2006 Report Posted June 15, 2006 Hi, I basically want to create a model of a 3D surface, with a 2D graph. I have the xy placement and I represent the height of any given point by its colour (maybe white is the lowest point, gradually going up to red, the highest point on the actual surface). So I want the graph to look like a bunch of points (a probe is going to pass along the surface and take these height measurements), where a bump on the surface would be indicated by the points gradually changing colour and gradually changing back as the probe moves off the bump. I've looked at all the packaged graphing examples included with LabVIEW and nothing seems close enough to help. Any other suggestions as to a BETTER way of representing this data are very welcome as well. I am at the stage where I can put the points wherever I want, but I have no clue how to change the colour. Thanks to all in advance, Adam EDIT: I am very new to LabVIEW, just to clarify. EDIT AGAIN: I'm looking into intensity graphs now...maybe I should have looked at them harder before, sorry guys. Quote
didierj Posted June 16, 2006 Report Posted June 16, 2006 adam85 said: EDIT: I am very new to LabVIEW, just to clarify. could have guessed, since it's in your profile. adam85 said: EDIT AGAIN: I'm looking into intensity graphs now...maybe I should have looked at them harder before, sorry guys. Nice to see that you found the solution yourself :thumbup: Quote
adam85 Posted June 16, 2006 Author Report Posted June 16, 2006 Alright, now I have a slightly new problem. I have an intensity graph, and I want to dynamically change the "Amplitude" or "Z Axis" or "Height" scaling. To be more clear, I want to be able to ignore all data points above a certain height for example (which I can figure out on my own) according to say a slider, and as the slider moves it also adjusts the intensity graph's "Amplitude" scaling so that the remaining data points appear in good contrast with each other. This was my idea for how to "zoom in" and isolate the areas that don't have as large bumps...any better way of doing this, and if not, how would you guys approach this? Thanks, Adam Quote
torekp Posted June 19, 2006 Report Posted June 19, 2006 adam85 said: Alright, now I have a slightly new problem. I have an intensity graph, and I want to dynamically change the "Amplitude" or "Z Axis" or "Height" scaling. To be more clear, I want to be able to ignore all data points above a certain height for example (which I can figure out on my own) according to say a slider, and as the slider moves it also adjusts the intensity graph's "Amplitude" scaling so that the remaining data points appear in good contrast with each other.This was my idea for how to "zoom in" and isolate the areas that don't have as large bumps...any better way of doing this, and if not, how would you guys approach this? Thanks, Adam Create a Property Node by right-clicking your Intensity Graph on the block diagram. Select Z Scale -> Range -> Maximum. (You can enlarge the Node to two lines and add Minimum as the next property too, if you want.) What this does is color all points at or above your Maximum as white. I figure and hope that's what you wanted. Quote
adam85 Posted June 20, 2006 Author Report Posted June 20, 2006 torekp said: Create a Property Node by right-clicking your Intensity Graph on the block diagram. Select Z Scale -> Range -> Maximum. (You can enlarge the Node to two lines and add Minimum as the next property too, if you want.)What this does is color all points at or above your Maximum as white. I figure and hope that's what you wanted. Thanks, this works - I thought it wasn't possible at first but all I had to do was right click and change the property node to a Write one. I feel smart. Thanks again for the help. Quote
adam85 Posted June 20, 2006 Author Report Posted June 20, 2006 OK another question, this one is probably also really easy to answer, but for some reason I can't figure it out. In the picture below you can see that i'm getting data from the serial port and building an array with said data. I want to do other things with this array (I have another case structure connected to a different button, that I want to write this array to an Excel file with). But since the array "exists" within the True case of the structure below, as soon as the button goes off again we're in the False case where i'm forced to wire an empty array, which the rest of the program effectively sees all the time. How do I fix this? Thanks. EDIT: Creating a Local Variable in the False case linked to the array in the True case and wiring it to the output, works. Is there a better/more widely accepted practice? Quote
Neville D Posted June 20, 2006 Report Posted June 20, 2006 adam85 said: OK another question, this one is probably also really easy to answer, but for some reason I can't figure it out.In the picture below you can see that i'm getting data from the serial port and building an array with said data. I want to do other things with this array (I have another case structure connected to a different button, that I want to write this array to an Excel file with). But since the array "exists" within the True case of the structure below, as soon as the button goes off again we're in the False case where i'm forced to wire an empty array, which the rest of the program effectively sees all the time. How do I fix this? Thanks. EDIT: Creating a Local Variable in the False case linked to the array in the True case and wiring it to the output, works. Is there a better/more widely accepted practice? Avoid using Local variables with arrays. Every local variable forms a copy of the data, and large arrays means lots of copies, and lots of calls to the Memory manager which can slow things down. You can also get race conditions if you have locals littered all over the code with multiple reads and writes occuring in different loops. Use a shift register that is intialized to an empty array to carry your data from the true case through the false case. Neville. Quote
adam85 Posted June 20, 2006 Author Report Posted June 20, 2006 Neville D said: Avoid using Local variables with arrays. Every local variable forms a copy of the data, and large arrays means lots of copies, and lots of calls to the Memory manager which can slow things down.You can also get race conditions if you have locals littered all over the code with multiple reads and writes occuring in different loops. Use a shift register that is intialized to an empty array to carry your data from the true case through the false case. Neville. Got that working, it's a much better way of doing it, thanks very much! (why didn't I think of this myself ) Adam Quote
