Bryan Posted September 27, 2006 Report Posted September 27, 2006 I've had LabVIEW 7.1 running successfully on Mandrake 10.1 for almost 2 years now. I just yesterday installed 8.2 (7.1 still installed) and have had problems getting it to do anything but load. I don't think it's related to having 7.1 on board, but anytime I try to create a new VI or anything, LabVIEW closes. I'm able to create a new project, and items within a project, but as soon as I try to open/edit anything, it closes. I launched LabVIEW 8.2 from a command prompt and when it closed I got the following error: LabVIEW caught fatal signal 8.2 - Received SIGSEGV Attempt to reference address: 0x0 Segmentation fault Anyone have any ideas? Quote
pallen Posted September 28, 2006 Report Posted September 28, 2006 Could it be this same thing? http://forums.lavag.org/index.php?showtopi...&hl=SIGSEGV Quote
Bryan Posted September 28, 2006 Author Report Posted September 28, 2006 Thanks for the link. It was actually a reminder. I had that issue with 7.1 and Fedora and had to do the tune2fs. I didn't have to do it when I installed 7.1 on Mandrake 10.1 for some reason. Mandrake had just become Mandriva at that time I believe (although I still hear it called Mandrake). I tried it and had the same problem. The NI Knowledge Base says that problem was fixed in 7.1.1, so I would assume it would be in 8.2 as well. Any other ideas? Quote
pallen Posted September 28, 2006 Report Posted September 28, 2006 Any other ideas? Unfortunately no. I've not had a chance to try LV 8.2 for Linux....or even for Windows yet. (Although the shiny new box for the Windows version is sitting beside me now) Hopefully you'll be able to find some info somewhere. Quote
Adam Kemp Posted September 28, 2006 Report Posted September 28, 2006 Bryan: Try this. From a terminal, run this command: strace labview > ~/strace.out 2>&1 Then do whatever it is that crashes LabVIEW and attach the strace.out file to this forum. I'll take a look at it. Quote
Bryan Posted September 29, 2006 Author Report Posted September 29, 2006 I did as requested and couldn't believe that it generated an 8MB file! I gzipped it down to 600-ish K. Now it seems when I start LabVIEW 8.2 that if I just let it sit for a little while at the welcome screen, it will shut down on it's own. I looked at the file created a little and saw things that said "File not found". Can't figure out why it wouldn't see them. Download File:post-404-1159530549.gz Quote
Adam Kemp Posted October 6, 2006 Report Posted October 6, 2006 I did as requested and couldn't believe that it generated an 8MB file! I gzipped it down to 600-ish K. Now it seems when I start LabVIEW 8.2 that if I just let it sit for a little while at the welcome screen, it will shut down on it's own. I looked at the file created a little and saw things that said "File not found". Can't figure out why it wouldn't see them. Wow, I'm sorry. I thought I was subscribed to this post, but I guess not. I'll take a look at the strace output and see if I can determine the cause. Quote
Adam Kemp Posted October 6, 2006 Report Posted October 6, 2006 I need more information. Add this to your .labviewrc file (in your home directory): labview.DPrintfLogging: True Then launch LabVIEW and get it to crash again. Then I want you to attach two log files from your /tmp directory. One will be named "LabVIEW_Failure_Log.username.txt" and the other will be "labview_8.2_username_cur.txt". Attach both of those. Quote
Bryan Posted October 9, 2006 Author Report Posted October 9, 2006 No problem. I'm not in a hurry to get this up and running at the moment, but I do want to get it running at some point. I've attached the files as requested. Thanks for your help! Download File:post-404-1160389352.txt Download File:post-404-1160389360.txt Quote
Adam Kemp Posted October 9, 2006 Report Posted October 9, 2006 This looks like an OSMesa issue. Which video card do you have? Here's a possible workaround (run these commands as root or use sudo): #cd /usr/local/natinst/LabVIEW-8.2#cp linux/libOSMesa.so.4.0 patchlib/libOSMesa.so.4 To verify that this worked correctly, you can do this: #ldd labview linux-gate.so.1 => (0xffffe000) libOSMesa.so.4 => /usr/local/natinst/LabVIEW-8.2/patchlib/libOSMesa.so.4 (0x40018000) libGL.so.1 => /usr/lib/libGL.so.1 (0x40180000) libX11.so.6 => /usr/X11R6/lib/libX11.so.6 (0x401e7000) libXext.so.6 => /usr/X11R6/lib/libXext.so.6 (0x402e0000) libdl.so.2 => /lib/libdl.so.2 (0x40308000) libpthread.so.0 => /lib/tls/libpthread.so.0 (0x4030d000) libstdc++.so.5 => /usr/lib/libstdc++.so.5 (0x4031f000) libm.so.6 => /lib/tls/libm.so.6 (0x403dd000) libgcc_s.so.1 => /usr/local/lib/libgcc_s.so.1 (0x40403000) libc.so.6 => /lib/tls/libc.so.6 (0x4040b000) libXxf86vm.so.1 => /usr/X11R6/lib/libXxf86vm.so.1 (0x4052a000) /lib/ld-linux.so.2 (0x40000000) Make sure that the libOSMesa line shows that path. Then try running LabVIEW again. Let me know if this does or does not help. If it does, be sure to let me know which video card you have (and if you've installed any specific driver for it) so we can try to test it next time. Quote
Bryan Posted October 9, 2006 Author Report Posted October 9, 2006 I'm actually (at the moment) running Manrake as a Virtual Machine on my office desktop computer which uses a Matrox dual-head video card (Millenium P650) I'll give those commands a shot and let you know. Thanks again! --UPDATE-- Nope, still does it. As I said before, I'm using a Matrox Millenium P650 video card, running Mandrake 10.1 on a Virtual Machine on my Windows XP Professional desktop computer. Quote
Adam Kemp Posted October 9, 2006 Report Posted October 9, 2006 VMWare or VirtualPC? If VMWare, do you have the VMWare Tools installed? Quote
Bryan Posted October 9, 2006 Author Report Posted October 9, 2006 Virtual PC (Windows), the 2004 version that Microsoft is/was offering for free a little while ago. I've tried to install packages for it, but won't do it for Linux. Quote
Adam Kemp Posted October 9, 2006 Report Posted October 9, 2006 Virtual PC (Windows), the 2004 version that Microsoft is/was offering for free a little while ago. I've tried to install packages for it, but won't do it for Linux. Is there a way to get Virtual PC to connect the VM's CD-ROM drive to a .iso file? I really don't want to burn these CDs just for a virtual machine. I know this can be done in VMWare, but I don't see the option in Virtual PC... :headbang: EDIT: I figured it out. What a silly way to do that... Quote
Adam Kemp Posted October 9, 2006 Report Posted October 9, 2006 Ok, this is definitely an issue with the DRI drivers/libOSMesa. I have a feeling that installing another version of Mesa would fix it, but in the process of trying to do so I was again reminded why I no longer use Mandrake. I couldn't find a binary update for Mesa, and the source version wouldn't compile because Mandrake doesn't come with all of the X headers. Then I was in RPM Hell trying to install them. You have two choices which both have about an equal chance of resolving this problem: 1. Go through the trouble of installing the X headers somehow, and then downloading and compiling/installing Mesa (mesa3d.org) from source. 2. Upgrade to Mandrake 2006. Both choices are annoying, but I'm not sure what else to suggest. Quote
Bryan Posted October 10, 2006 Author Report Posted October 10, 2006 Well, I've been using mandrake 10.1 because of it's ability to install to and run from a USB HDD without modification. I've been using this drive for testing of multiple OS-less units (it allows us to exercise I/O without having to install an OS and test apps), but I also do my development on it as well. I've installed 10.1 in a Virtual machine on my desktop so that I don't have to do development on the drive. I'm not at a very good point now to try the Mandrake upgrade and pray that it will work on my bootable HDD. I don't want to risk breaking what already is working for us. I'm also somewhat of a Linux novice (I know just enough to be dangerous), so doing the Mesa upgrade probably isn't something I want to bother taclking at the moment. Thanks anyway for all your help! At the very least, I know what I need to do if I get to the point I can upgrade to 8.2 in Linux. Most of the stuff I do is in Windows anyway, just this one part of a current project involves Linux. Quote
