telurkuda Posted November 30, 2006 Report Posted November 30, 2006 is there any of you can help me to do this??? i need my chart can not only plot point but also text data and number. regards. Quote
James N Posted November 30, 2006 Report Posted November 30, 2006 Search for "annotation" in the LabVIEW Help->Find Examples : Programmatically Annotate a Graph.vi I don't think this feature is available before LV 8.0. -James Quote
peteski Posted November 30, 2006 Report Posted November 30, 2006 is there any of you can help me to do this???i need my chart can not only plot point but also text data and number. regards. I don't think that this post really belongs in "Real-Time", it should be more appropriate in either: LAVA > Software & Hardware Discussions > LabVIEW General or LAVA > Software & Hardware Discussions > LabVIEW (By Category) > User Interface Regardless, It may be possible to do what you want using string indicators that are configured to overlap your graph and by using property nodes place them in spots over your graph, if you don't want to upgrade to a version >7.1, but its a path that is likely to be a bit ugly and un-elegant, for what it is worth. This is just the first thing that comes to my mind, but there may be other possibilities for vesions < 8.0. -Pete Liiva Quote
Grampa_of_Oliva_n_Eden Posted November 30, 2006 Report Posted November 30, 2006 For a pre-anotation solution you could use the code CC posted in this thread. http://forums.ni.com/ni/board/message?boar...ssage.id=125040 on the NI forum. In that example he controls all of the aspects of the cursor using a reference to the cursor legend. Un-fortunately that method has been shutdown for LV 8 or greater. And if none of the above help out, you can always use a picture control and "roll your own". If you go that route then this thread http://forums.ni.com/ni/board/message?boar...4&jump=true contains a bunch of links that I have been collecting to help get stated with the Picture control. Here is a sample of what can be done with a pcture control (note:This example is NOT part of that thread). Ben Quote
telurkuda Posted December 2, 2006 Author Report Posted December 2, 2006 thanks for the information, but i have clearly said that i want to plot those data on a CHART, not a GRAPH, coz i need the strip type of chart. chart doesn't have annotation property. Quote
Grampa_of_Oliva_n_Eden Posted December 2, 2006 Report Posted December 2, 2006 ...but i have clearly said that i want to plot those data on a CHART,... Thenyou only choice is the picture control! Ben Quote
